Control edit issue permissions differently for different issue types
Vadim Yerokhin
September 14, 2017
I'd like to set up permissions in such a way that one group of users can edit stories and another can only edit subtasks/bugs.  Is this possible?
Currently it seems that the permission scheme groups all issues together without a way to distinguish between them.
Bhushan Nagaraj
September 14, 2017
Hi Vadim,
You can use Advanced Workflow Properties and set the jira.permission.* to  the groups you would like to restrict to. This is done at the workflow level, hence allowing you to have different workflows for each issue type.
jira.permission.edit.group=jira-administrators means that only JIRA administrators can edit an issue
https://confluence.atlassian.com/adminjiraserver073/workflow-properties-861253674.html
Bhushan
