We use Jira 5.0.2 with Greenhopper, and I am trying to adjust our workflow to prevent users from logging work against an issue that has not been moved to In Progress. I tried adding a property to the Open step that would deny the ability to log work:
jira.permission.work=denied
I also tried this variation, based on an articale I found at j-tricks.com:
jira.permission.work.denied=denied
Unfortunately, neither seemed to work. Am I going about this the right way?
I don't know if there are any changes in JIRA5. Can you also try this?
jira.permission.work.user=someuser
and see if anyone else have access. You can give some invalid user if the comments are true :)
