×Is there any plugin or script that will control whether a workflow transition is allowed depending on the statuses of linked issues?
For instance: Issue X can be resolved only if all of its <name_of_ralation> issues are closed.
Thanks in advance,
you can do it by using conditon(All dependent issues need to be resolved) in script runner plugin, check this document
https://jamieechlin.atlassian.net/wiki/display/GRV/Conditions
or you can try with following plugin by upgrading/modifying it's source code to latest version
