Convert Scrum Project to a kanban Project
Bunty
Hi Everyone,
How to convert  scrum project to a kanban project?
Thanks in Advance,
Bunty
Stephen Hayden
March 20, 2019
Think of your Scrum / Kanban boards as really advanced filters/dashboards.  You can make as many as you want and you just supply the filter that populates it.
Go to Boards, View all Boards.  Create Board is in the upper right.
Once the appropriate board is created, you can go to your project, and the 3 dots below the project icon in the upper left (on early 7.x UI) allow you to switch between boards relevant to that project.
Whether Scrum or Kanban, it is simply a Software project.
Ievgeniia Matushchenko
October 16, 2019
Your backlog section will be missing if you simply add extra board. And you will need to enable it and make some changes to workflow
