Copy Custom Fields remotely using script runner.
Tarun Sapra
hi,
Is it possible to copy custom field from another JIRA instance in the same network ?
Regards
Tarun
Bob Swift
January 20, 2014
JIRA Command Line Interface can be used get values from one instance and then populate the other. Useful when you are writting custom integrations between systems including JIRA to JIRA.
Henning Tietgens
January 20, 2014
For doing something like this you have to use the JIRA REST interface of the other instance on one of the instances to get the values from the other instance.
tsapra January 20, 2014
Hi Henning, Yes i have used REST API for such kind of work, i was looking for a more of "built-in" alternative...but anyways i guess would have to write some scripts :)
Tarun Sapra
