×hi,
Is it possible to copy custom field from another JIRA instance in the same network ?
Regards
Tarun
JIRA Command Line Interface can be used get values from one instance and then populate the other. Useful when you are writting custom integrations between systems including JIRA to JIRA.
For doing something like this you have to use the JIRA REST interface of the other instance on one of the instances to get the values from the other instance.
Hi Henning, Yes i have used REST API for such kind of work, i was looking for a more of "built-in" alternative...but anyways i guess would have to write some scripts :)
