Copy Custom field to a linked issue
Jital Jain February 5, 2020
I have a custom field "Sponsor" on an Initiative .
Is it possible to copy the custom field sponsor to all Epics linked to the initiative?
Fernando Bordallo
February 6, 2020
Hello @Jital Jain
When you say 'copy the field' do you mean the value of the field? would you also be looking to keep it in sync if the value changed? 🤔interesting problem
Jital Jain February 7, 2020
Yes thats correct I meant value of the field. Yes value should be in sync based on the parent.
Example
I have an Initiative with field "Sponsor". The initiative is linked to three EPICS which also has the field Sponsor. I would like the field "Sponsor" of the linked issues to  be in snyc with the parent.
Fernando Bordallo
February 9, 2020
I can't think of a way of doing with the any out of the box feature, but you might be able to pull this off with a script (ScriptRunner) listening for updates to the initiative
