×Thanks Bob.
How do I access the JCLI for the OnDemand? is that a local install or some remote service?
Also I saw at some other post that cloneProject for the OnDemand will not include the issues, is it?
Thanks a lot.
JCLI is a client program that runs on your PC and works remotely against an OnDemand instance the same as any other instance. Follow the installation instructions in the link provided.
