Same here, chrome on ubuntu. Cannot paste text into a comment or description.
Same issue for using Jira in Microsoft Edge. We can use ctrl+v and it works but when we right click, paste is not an option?
+1 Seen this issue on Windows, MacOS + Ubuntu.
Copy & paste seems to work when:
- Close ticket from editor view (EG press Save)
- Copy text
- Open editor view
- Paste
Any news about this? I just started having the same problem, using ubuntu 20.04, latest Opera-stable
Same, Chrome with Ubuntu Wayland.
Same issue - Ubuntu 20.04 LTS
Same on Windows10, with Firefox, no C&P, unbelievable.
I don't know if this helps anyone, but I had a similar problem. My problem was that I could not paste into the description field of an issue in Jira. However, I found that if I pasted the text into a text editor (Notepad), and then copied from Notepad, I could paste into the description field. Not sure why that works, but maybe it's because the description field doesn't support rich text, or some formatted version of text for PASTE, although it obviously allows me to create rich text in the description field text editor box. It's an odd problem to be sure.
Same for me, I could not paste into the `Activity comment`, but I could paste (the same text) into the checklist field! Although refreshing the browser makes it work - it is really annoying ... because it should be a really simple task where `ctrl+v` works, but it doesn't, so you need + `F5` + wait + a new `ctrl+v `
Same here for me in the new view, old view works just fine. Ubuntu 20.04 and Chrome.
