I tried this to get the token :
AP.context.getToken(function(token){
console.log("JWT token string", token);
and tried this to get the user details :
AP.user.getCurrentUser(function(user) {
console.log("The Atlassian Account ID is", user.atlassianAccountId);
but both didn't work
Hi @Ajay poly,
It would be better to ask this in the Atlassian Developer Community forum since it is a development question.
In the interest of unblocking you quickly, the APIs you are trying to use are for Atlassian Connect iframes, but since you mention "forge-react app", you are probably looking for Forge CustomUI APIs which are documented here. Specifically, you probably need to call view.getContext() and use the returned accountId.
Dugald
