[Could not find workflow status for issue] trouble
leejimin1006 July 9, 2012
Hello, I'm developer in JIRA plugin.
To change workflow of Issue, I executed order-word on source which change it to non-existent workflow.
WorkflowTransitionUtil workflowTransitionUtil = JiraUtils.loadComponent(WorkflowTransitionUtilImpl.class);
workflowTransitionUtil.setIssue(issue);
workflowTransitionUtil.setAction(Integer.parseInt(req.getParameter("status")));
workflowTransitionUtil.progress();
Following execution, error screen that I attached appeared
I tried to delete the issue. But the error appeared constantly.
Plz, Give me a solution.
Cause:
java.lang.RuntimeException: Could not find workflow status for issue NFT-1850.
Stack Trace: [hide]
	at com.atlassian.jira.permission.PermissionContextImpl.getStatusGV(PermissionContextImpl.java:107)
	at com.atlassian.jira.permission.PermissionContextImpl.getRelevantStepDescriptor(PermissionContextImpl.java:84)
	at com.atlassian.jira.permission.WorkflowPermissionFactory.getWorkflowPermissions(WorkflowPermissionFactory.java:30)
	at com.atlassian.jira.security.WorkflowBasedPermissionManager.hasPermission(WorkflowBasedPermissionManager.java:75)
	at com.atlassian.jira.security.AbstractPermissionManager.hasPermission(AbstractPermissionManager.java:107)
	at com.atlassian.jira.security.AbstractPermissionManager.hasPermission(AbstractPermissionManager.java:130)
	at sun.reflect.GeneratedMethodAccessor139.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
	at java.lang.reflect.Method.invoke(Method.java:597)
	at com.atlassian.util.profiling.object.ObjectProfiler.profiledInvoke(ObjectProfiler.java:81)
	at com.atlassian.jira.config.component.SwitchingInvocationHandler.invoke(SwitchingInvocationHandler.java:28)
	at $Proxy46.hasPermission(Unknown Source)
	at com.atlassian.jira.bc.issue.DefaultIssueService.hasPermissionToView(DefaultIssueService.java:779)
	at com.atlassian.jira.bc.issue.DefaultIssueService.getIssue(DefaultIssueService.java:852)
	at com.atlassian.jira.bc.issue.DefaultIssueService.getIssue(DefaultIssueService.java:108)
	at sun.reflect.GeneratedMethodAccessor1152.invoke(Unknown Source)
	at com.atlassian.multitenant.impl.MultiTenantComponentFactoryImpl$AbstractMultiTenantAwareInvocationHandler.invokeInternal(MultiTenantComponentFactoryImpl.java:181)
	at com.atlassian.multitenant.impl.MultiTenantComponentFactoryImpl$MultiTenantAwareInvocationHandler.invoke(MultiTenantComponentFactoryImpl.java:211)
	at $Proxy397.getIssue(Unknown Source)
	at com.atlassian.plugin.osgi.hostcomponents.impl.DefaultComponentRegistrar$ContextClassLoaderSettingInvocationHandler.invoke(DefaultComponentRegistrar.java:129)
	at com.atlassian.plugin.osgi.bridge.external.HostComponentFactoryBean$DynamicServiceInvocationHandler.invoke(HostComponentFactoryBean.java:154)
	at com.neople.plugin.issue.servlet.IssueCRUD.doGet(IssueCRUD.java:115)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
	at com.atlassian.plugin.servlet.DelegatingPluginServlet.service(DelegatingPluginServlet.java:42)
	at com.atlassian.plugin.servlet.ServletModuleContainerServlet.service(ServletModuleContainerServlet.java:52)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
	at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:74)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
	at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:44)
	at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46)
	at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66)
	at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:25)
	at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74)
	at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42)
	at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77)
	at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63)
	at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.executeRequest(AccessLogFilter.java:103)
	at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.doFilter(AccessLogFilter.java:87)
	at com.atlassian.jira.security.xsrf.XsrfTokenAdditionRequestFilter.doFilter(XsrfTokenAdditionRequestFilter.java:54)
	at com.opensymphony.sitemesh.webapp.SiteMeshFilter.obtainContent(SiteMeshFilter.java:129)
	at com.opensymphony.sitemesh.webapp.SiteMeshFilter.doFilter(SiteMeshFilter.java:77)
	at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:211)
	at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:98)
	at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:150)
	at com.atlassian.jira.web.filters.JiraLoginFilter.doFilter(JiraLoginFilter.java:70)
	at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:71)
	at com.atlassian.util.profiling.filters.ProfilingFilter.doFilter(ProfilingFilter.java:99)
	at com.atlassian.jira.web.filters.JIRAProfilingFilter.doFilter(JIRAProfilingFilter.java:19)
	at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:71)
	at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:350)
	at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:75)
	at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:51)
	at com.sysbliss.jira.plugins.workflow.servlet.JWDSendRedirectFilter.doFilter(JWDSendRedirectFilter.java:25)
	at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:33)
	at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31)
	at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:41)
	at com.atlassian.jira.web.filters.PathMatchingEncodingFilter.doFilter(PathMatchingEncodingFilter.java:49)
	at com.atlassian.jira.web.monitor.ActiveRequestsFilter$PassToChainFilterFunc.doFilter(ActiveRequestsFilter.java:346)
	at com.atlassian.jira.web.monitor.ActiveRequestsFilter$DebugLogFilterFunc.doFilter(ActiveRequestsFilter.java:463)
	at com.atlassian.jira.web.monitor.ActiveRequestsFilter.doFilter(ActiveRequestsFilter.java:173)
	at com.atlassian.jira.startup.JiraStartupChecklistFilter.doFilter(JiraStartupChecklistFilter.java:75)
	at com.atlassian.multitenant.servlet.MultiTenantServletFilter.doFilter(MultiTenantServletFilter.java:91)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
	at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:554)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
	at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:190)
	at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:291)
	at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:776)
	at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:705)
	at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:898)
	at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:690)
	at java.lang.Thread.run(Thread.java:662)
Jobin Kuruvilla [Adaptavist]
July 9, 2012
First of all, use issueService in the later versions of JIRA to transition issues.
Secondly, actionId is not status id. It is the id of the transition. You can find it in the workflow along side the tranisition of you are looking at the steps view.
See "Suing text edit more" screeshot under https://confluence.atlassian.com/display/JIRA/Configuring+Workflow#ConfiguringWorkflow-Workingwithsteps
Hi, Jobin Kuruvilla. Thank you for your answer.
But I wish to delete the "Error Issue", forcibly.
Do you have other answer?
Nic Brough -Adaptavist-
July 9, 2012
Try the integrity checker to undo the damage you've done, then you should be able to delete it ok.
If that doesn't work, then you'll need to write something to undo the damage!
leejimin1006 July 10, 2012
Hi, Nic Brough. It's very nice advice.
But... unsolved ! T_T
Integrity checker(select all) don't found "Error issue"
July 10, 2012
Ok, that means you've done damage that the integrity checker cannot fix. You will need to write something to directly undo what you've done, or hack the database directly.
leejimin1006 August 5, 2012
HaHaHa.. Good answer. I will hack the jira-server database. sometime...
Thank you. In fact, I requested JIRA Support Center.
August 5, 2012
I suspect Jira support will tell you to reverse your changes to the data and re-run the integrity checker.
