we are currently evaluating the Structure plugin and it looks really good so far. It provides an easy way to add, manage, and visualize tasks.
We have a few questions about its integration with another Jira plugin: Jira Agile.
Again, the plugin is really awesome. If the things mentioned above cannot be achieve in the normal way, is there a workaround, another plugin, or any other thing that can help us achieve that?
Thank you!
-Martim
Hi Martim,
Thanks for using the Structure plugin and for the great feedback!
In order of questions:
Robert
Hi Robert,
first of all, thank you for your quick reply.
Here is more a more detailed exxplanation of the problems I am having:
0) Initial configuration doesn't reflect Jira board
1) Reordering Stories inside Structure doesn't reflect in Jira Board
2) Reordering Sub-Tasks not working
I'll try adding the column for the Sprint.
Thanks!!
Robert,
apparently adding the Sub-Task filter was causing the issues mentioned above. I've created a new Structure with only the Filter and Greenhopper syncs, and everything works.
I'll keep you posted about #3.
Martim, you beat me to it!
I'm glad you got that sorted, looking forward to the update.
Robert,
my last question (I promise!!!)... I added the Sprint field to the Edit screen and as a column to my view in Structure. Everything works perfectly, but I need to enter the Sprint ID as a number (for instance, "76"). Any way to allow me enter it as a string, like "Sprint 4"?
Thank you one more time!
Martim, no worries! Keep them coming.
Unfortunately no, the Sprint field in JIRA only takes the sprint ID. Sprint names in JIRA Agile are not unique.
A quick way to get a sprint ID without leaving Structure is to go to the search bar, switch to JQL and type "search =" and start typing the sprint name. Find the sprint you want in the auto-complete suggestions, and its ID will be in brackets at the end.
Robert,
Currently when I reorder the subtasks inside Structure, the subtasks are not reordered in the Jira Board.
Is this something I am doing wrong? Or Jira Board doesn't support sub-tasks reordering?
Thank you!
Hi Martim,
Which JIRA Board do you mean? Kanban or Scrum?
The Kanban board updates automatically, whereas the Scrum board requires a page refresh.
If that doesn't help clear things up, could you add a screenshot of your synchronizer settings page again?
Also: Is it only sub-tasks that aren't being reordered? If you reorder stories in Structure, is this being synced to your Agile boards?
Hi Robert,
Here's the screenshot of my current Structure Sync Settings: http://screencast.com/t/jbGStJP6
And here are the issues that I'm facing:
Thank you so much for your help!
PS: Do you work for Structure? And also is it possible to schedule a time and jump in a skype call so you can sort my questions out? I will be more than happy to pay for it :)
Hi Martim, it's no trouble at all, happy to help!
I do indeed work for Structure's creators, ALM Works. I'm afraid we don't offer live support, but our online support via https://jira.almworks.com is second to none!
A quick diagnosis from the screenshot - your Agile synchronizer is set up to sync with the wrong board. Disable or delete that synchronizer and set up a new one, this time be sure sure to select the 'MARTIM TEST' Scrum board in the list of Agile boards.
Leave all the boxes ticked, create, resync and enable, everything should work fine. If not, let me know :)
For reference: JIRA Agile synchronizer documentation.
Those side-by-side screencasts rock.
