Create Issue on transition
Jan Sękara October 3, 2016
Is it possible to pop up create issue window on transition, on contition that it's in Epic's workflow and it will automaticly pop up the same window that "create issue in epic" does?
Daniel Bajrak
October 3, 2016
Hi Jan,
you can create an issue based on template during transition in post function using one of plugins in marketplace f.e. Issue Template. You can populate fields also with value from "parent" issue. There is no other possibility to create issue during transition.
Best Regards,
