×Hi ,
any one have any idea why it is taking long(around 20Sec) time to popup while trying to create a issue.
It's extremely slow after a cache clear event. My profiling show it's proportional to the number of field configs * number of fields, and also number of projects * number of roles, as there will be a db query for (N projects * M roles).
After you have loaded the dialog once, it should then be much faster . Is it?
yah, it is fast once the dialog loaded once,
any suggestion, how to over come this?
And btw you're lucky, it takes around 90 seconds for that dialog to popup after the caches have been cleared on my instance...
How many projects and issue types do you have? It is directly dependent on that.
projects will be around 360 and issue types will be around 50
butwith same projects and isuuetypes test instance created and we are not seeing this issue
Hey there, Rambanam.
Perhaps you can try to check on the following documentation to narrow down the possibilities that could cause the performance degradation in your instance
https://confluence.atlassian.com/display/JIRAKB/Crashes+and+Performance+Issues+Troubleshooting
Since there are many possibilities, take time to look into one by one and hopefully, you are able to find the reason behind this.
Warm regards,
Danial
Thanks for your response,
i went through the document , our jira will work fine except slowness while loading create issue popup
