Create JIRA issue from GMAIL
Santiago Redondo
January 14, 2013
Hi everyone, Im currently using the JIRA plugin on Thunderbird to raise tickets. Is there a way to have this directly on Gmail through an extension or something?
Thunderbird doesn't work so well..
Thanks!
Stacey E. Kimmel-Smith
Hi All, who is using JTG Gmail to Jira? What are your thoughts?
Markus Hääl November 28, 2018
You can actually really easily do it with all the tutorials there are. There is just one pain point that in 90% of the cases is not described.
Besides IMAP you need to enable "less secure apps" from your google account.
This window is at Google account>sign in & security>Allow less secure apps: ONless secure.PNG
darylchuah
January 14, 2013
Perhaps JIRA Enterprise Mail Handler is what you looking for : https://marketplace.atlassian.com/plugins/com.javahollic.jira.jemh-ui
It has extensive feature and it is highly configurable to suit any kind of customization.
Deleted user January 19, 2013
JEMH can just pickup incoming email from: particular domains, eg @gmail.com, in a way you want, eg create & comment in project/issueType/priority/assignee etc.
Rahul Aich [Nagra]
January 14, 2013
Yes, you can create jira issues by directly sending emails to a gmail account.
Here's the steps.
https://confluence.atlassian.com/display/JIRA/Creating+Issues+and+Comments+from+Email
Rahul
Santiago Redondo
January 14, 2013
Um, that's pretty much what Im doing with Thunderbird, and I need to get a mail handler out of the equation.
I'm looking for some sort of a plugin or extension which will let me pick out emails from gmail and create jira issues from them, not set rules or anything like that.
The plugin would be linked to my current jira server, and all I'd have to do is set the options and insert the comment for the newly created ticket.
Im looking for something like that :)
Peter Davis
February 17, 2021
Steve Benjamin July 4, 2017
You can use this amazing Add-On to Integrate Gmail directly to JIRA
Gmail to JIRA Add-on
and you can also use this add-on to integrate Outlook directly to JIRA
Outlook To JIRA Add-on
Renjith Pillai
January 19, 2013
