I'm trying to create a Jira automation that will send a webhook post to start a google appscript function.
I'm struggling to get the set up correct and I believe its because the google environment is closed to internal organisation users only. Is there anyway to pass authentication information in the automation to access the app script function?
Hi @Harry Lee
From the Jira side there is no way to bypass settings your IT has setup. However you can reach out to your IT team and see if they will whitelist the atlassian products so that it can work properly with your other tools. Having been a google admin I know this is possible, however at the same time security teams do not always approve these requests.
Best,
Clark
