Create a Issue ticket in Jira via airflow dag when the dag status is fail?
abhishek raj
August 20, 2021
I would like to create a ticket whenever the dag status is fail with dag ID.
I would like to do it without any third party library in python not sure if this is possible or not.
I have work around Jira hook and operators from airflow 2.0 using below as reference.
wanted to know its right way to do and how can i achieve this.
https://github.com/BranchMetrics/incubator-airflow/blob/master/tests/contrib/operators/test_jira_operator_test.py
https://stackoverflow.com/questions/65846976/passing-xcom-value-to-jiraoperator-in-airflow
Ismael Jimoh
August 20, 2021
Hi @abhishek raj
If you are willing to write the code, you can add a rest api script that runs at intervals and pools tickets or is fired when your conditions are met in the source.
You can read about Jira cloud rest api here: https://developer.atlassian.com/cloud/jira/platform/rest/v2/api-group-issues/
Make sure you decide if the if is parsed before hand.
abhishek raj
August 20, 2021
Thanks @Ismael Jimoh
