I have 2 workflows in my Jira project : one for bugs and one for evolutions. I would like to create another workflow that will link these two worflows on the dev activity aspect.
The aim is to implement a Kanban based on this third workflow.
Is it possible ?
Thanks in advance,
@Satc Gyllchrist
Boards are just ways to view issues and each board has its own status management configuration.
As long as the corresponding workflow status from bugs/ evolutions/ Kanban intersect in the column management configurations of the boards, then you can see (or not see) the issues as they move through the workflow.
Thanks you for your answer. I try it but is’t possible to add rules each colums ?
@Satc Gyllchrist I am not sure what you are meaning. You can add columns, map statuses to columns, or add issue count constraints. The statuses from the workflows must be in a column to make issues visible on your boards. Your boards can have different columns, but status should still be mapped.
Ex.
Workflow for Bug = {B-To Do, B-In Progress, B-Done}
