×Hi All,
I am willing to know if we can add entry to Change log manually using python-jira library?
I want to display the custom field values that are calculated through JEP-Enhancer Plugin.
Hi @ssuhas91 ,
What is the purpose adding into changelog ?
Of course, you can add using sqlalchemy and xml module the change history:)
I do recommend not do it :)
