i have an plugin and added a new .js-File to the context. But it is not working inside the issue create dialog.
I used this context inside the atlassian-plugin.xml
<context>jira.rich.editor</context>
<context>jira.view.issue</context>
<context>jira.edit.issue</context>
<context>jira.create.issue</context>
<context>gh-rapid</context>
<context>atl.general</context>
If the dialog is open on top of the issue view its working but not for example on the dashboard.
Best regards
Daniel
If you're building apps for Jira maybe you get swifter replies if you post questions in developer community see https://community.developer.atlassian.com/
all the best
Lisa
