Hello!
I need to finde a way to create an issue in a remote JIRA instance. I am using inTENSO plugin to syncronize them both, but the tricky part is that I need to create an issue in Instance B, when a flow transition a status (let's say from open to in progress) in Instance A.
Is there any way using groovy?
Thanks!
Hi Team,
Any groovy script available to create issue from JIRA on remote application(like servicenow,qradar).Please let me know.
A few add-ons in the Atlassian Marketplace can do this. On top of my head, the JIRA ScriptRunner would since it will basically let you run a groovy script on a post-function. You will then just have to create the groovy code that will create an issue type, the SR add-on will also allow you to get some values from the JIRA issue itself!
@Gabrielle Bautista [ACP-JA] sorry, I misscreated the issue title. I am updating now!
