Hi
i am trying to add a Description using Bob Swift, i am getting blank. where i am add custom field
%customfield_10011% was enabled on, %customfield_12007% by %parent_assignee%.
Hi @G Ashok ,
Please use the substitution variable %original_customfield_ID% or %parent_customfield_ID%. Make sure the original issue where you are performing the transition has a value for the respective fields. Refer to the documentation here.
We have opened a support ticket, SUPPORT-10080 to better track your request. Please access the ticket and make sure that it is accurately showing you as the reporter.
If you need us to make any changes to the reporter field or are unable to access the ticket, please let us know here in this thread.
Suprija
