The create account option changed and there is no way to create a project with setting based on an existing project. how can I get the capability back? in addition, can I duplicate project including tasks?
Maya
Hi @Maya Arad ,
you should be able to create a project with shared configuration (https://support.atlassian.com/jira-software-cloud/docs/create-a-new-project/).
About coning, you cannot do that using built-in feature. You could try using JIRA Command Line Interface. This plugin is compatible with JIRA Cloud and using it's cloneProject command.
Hope this helps,
Fabio
Hi @Maya Arad ,
It hasn't change! You can still choose to create a project based on an existing configuration! You'll find it on this screen
Hope that helps!
Alex
