The schedule task permission is built in. I have one role that I want to be able to set and change the Due Date. However, I want everyone to be able to see the Due Date. How do I do that?
TIA
I believe that would be a field level permission which isn't supported - check the workarounds listed to see if any might work for you but I don't think they will without a pretty serious scripted solution of some sort, that I'm not sure is even possible (a little out of my wheelhouse)
https://jira.atlassian.com/browse/JRASERVER-1330
