Create second Jira Instance with same ID?
Wayne Bishop
September 26, 2016
Hi Folks;
I currently have a paid JIRA account under my own consulting company, but would like to create a second instance (with the same ID) for a separate client project. Wondering if this is possible and how to complete.
Regards;
-Wayne
Mathiyalagan
September 26, 2016
you mean license key?
Mathiyalagan
September 26, 2016
As per Atlassian you have to buy two separate license whether if you split the instance or each SEN will work for individual installations.
But original license will work but its against policy. To know more please check with Atlassian advocate in support portal
Nic Brough -Adaptavist-
September 26, 2016
What does "with the same ID" mean?
If you have two production systems, you need two licences for them.  I'm really not sure what the question actually means.
