Create subtask on transmission: parents security level is not copied into the subtask
Axel Dellenbach February 19, 2013
Dear all,
I've added the 'create subtask on transmission' function into my workflow. Using this function the subtask is created, but the subtask security level is always 'none', instead of the parent issue security level.
How I've to adjust my workflow to prevent this? My subtasks always should have the parents issue security level.
Thanks - Axel.
MJ
February 19, 2013
If you have configured a separate workflow for sub-tasks, you can add a post function to the "Create" transition called "Set Field Value from Parent" to take over the Parents securtity level. I have tested and confirmed this to work when manually creating a subtask from within an issue, I am not sure if the same behavior is possible when you are using a plugin or any other methods where you automatically create a sub-task through a workflow transition in the parent issue.
Axel Dellenbach February 24, 2013
Hi Mick,
I can't find a post function "Set Field Value from Parent", but maybe this is a JIRA version issue as we run actually JIRA 4.4.3.
Any idea?
Cheers - Axel.
Bob Swift
February 20, 2013
If you are using the Create on Transition Plugin for JIRA, then the security level should be set. If this is not happening, open an issue with the details.
