I am trying to create a new test case using Zephyr add-on in Jira. I navigate to Tests/create a test. A window appears wih Project and a Issue type dropdown. The only issue type that displays in the dropdown is Task. How do I set Issue type as Test?
Hi Kiffany.
To use Zephyr in a project, you just need to have the Test issue type associated with the Issue type Scheme of the project.
If you are having trouble on getting Zephyr to work with JIRA, you can get help in http://www.getzephyr.com/support
Cheers!
Teilor
That worked. Thanks!
