Hi
Is there a way to specify more than 300 Days Previously? I would like to show 365 if possible.
Thanks in advance
Hey Dennis, it should be possible to set the created vs resolved gadget to show for previous 300 days as that's the most limit of the gadget.
Simply do the following:
With our add-ons Great Gadgets for Jira Server and Great Gadgets for Jira Cloud you can have a Created vs Resolved chart on your dashboard that allows selecting a time range (more than 300 days).
In the 10 gadgets offered by the add-on, there is a Release Burndown / Burnup Chart gadget than can be easily configured as Created vs Resolved Chart. Just take a look at this example.
Danut
Hello Denise, Teck, et. al.
I would like to know the answer to this one as well.
After modifying jira.chart.days.previous.limit.daily in the jira-config.properties file to be greater than 300 to no effect on the Created vs Resolved Chart, however the modification did have the desired effect on the Recently Created Chart.
Hi Teck, No there is a limit of 300 and I want to key in more than 300 and was hoping there was a way I could do that.
