Creating Help for Custom field
Brian Taylor
I am trying to add Help Text to custom fields using javascript but find that if I have two fields that have the javascript only one set of help text is displayed
Blocked Reason custom field
Select appropriate reason code associated with this issue
<script type="text/javascript">
function showHelp() {
var listenersDiv = document.getElementById("bcFieldHelp");
if (listenersDiv.style.display == 'none') {
listenersDiv.style.display = '';
} else {
listenersDiv.style.display='none';
</script>
<a href="#" onclick="showHelp(); return false;"><img src="/images/icons/ico_help.png"/></a>
<div id="bcFieldHelp" style="display:none">
<center><b>Blocked Definitions</b></center>
<table border="1", cellpadding="2">
<tr>
<th>Reason</th>
<th>Definition</th>
</tr>
<tr>
<td>Waiting on another Dev Team/Project</td>
<td>Waiting on an issue in another team’s queue to be completed; need another dev team’s help in order to proceed etc.</td>
</tr>
<tr>
<td>Business dependency</td>
<td>Seeking further clarity in requirements; on hold due to an issue/question that requires business direction etc.</td>
</tr>
<tr>
<td>Dependent on another card in current Project</td>
<td>Need to wait until another card in this project is completed.</td>
</tr>
<tr>
<td>UX/Design dependency</td>
<td>Waiting on final mock-ups; need UX team’s help in order to proceed.</td>
</tr>
<tr>
<td>SysEng/DBA dependency</td>
<td>Waiting on the SysEng team or DBA team to complete a task.</td>
</tr>
<tr>
<td>Networking/Infrastructure dependency</td>
<td>Waiting on the networking team, waiting for server set up etc.</td>
</tr>
<tr>
<td>Legal/Contract dependency</td>
<td>Waiting on a contract to be finalized.</td>
</tr>
<tr>
<td>External dependency</td>
<td>Awaiting an external partner to send us data, update their system, validate a change etc.</td>
</tr>
<tr>
<td>Other</td>
<td>Reason not listed in the dropdown.</td>
</tr>
</table>
</div>
Story Points Field
Measurement of complexity and/or size of a requirement. </br>
<font color="red">Story Point size range should be between 1 and 10</font>
var listenersDiv = document.getElementById("spFieldHelp");
} else {
</script>
<div id="spFieldHelp" style="display:none">
<center><b>Sprint Sizing Definition</b></center>
<ul>
<li>1 point = 1/2 day of work for 1 pair; therefore a pair does 2 points per full day (for estimating purposes).</li>
<li>For single dev. work, a single dev. would do 1 point per day. </li>
<li>Point sizes need to reflect development, QA, and acceptance.</li>
<li>A single (1) point is the lowest amount of work (i.e., if something takes 2 hours, it still remains a 1 point effort).</li>
<li>Points are determined in a linear fashion, 1, 2, 3, 4, 5…10.</li>
</ul>
</div>
If both Fields exit on the screen the help text only displays one set of text for both fields
  1. In my case, if a click on the help fo Story Points I get the text for Blocked Reason and Blocked Reason gets the correct text
  2. If I edit an issue that click on the help text icon I get nothing
Screen Shot 2019-01-31 at 5.01.30 PM.pngScreen Shot 2019-01-31 at 5.01.07 PM.png
Ryan November 19, 2024
Hi @Brian Taylor & @Jira Support Team _ Smals! Were either of you able to find a workaround to this problem? We are currently seeing this same problem, so I'm on the hunt for a solution. Thanks!
Jira Support Team _ Smals March 23, 2020
We have the same issue when adding help in the description of three of our custom fields.
It is annoying.
