I was wondering if there was any way to create and print out a complete project list with all the detailed information on it. This list needs to have all the projects I've created on it. I've been trying to look around JIRA to see if I could find out myself but I've had no luck.
Hi Andrew,
You can easily get a list of projects along with any required information about them using the Intelligent Reports plugin.
You design your report template in Microsoft Word, then use simple point and click rules to fill it in with data from JIRA. No scripting or API to learn.
Try the 30 day free trial to see if it meets your needs.
