I just need to define the link to the parent issue when the child gets created and I can't find any example of how to do this.
def taskType = get('/rest/api/2/issuetype').asObject(List).body.find { it['name'] == 'Warranty Claim Robot Component' }['id']
post('/rest/api/2/issue')
        .header('Content-Type', 'application/json')
        .body(
                fields: [
                            summary    : 'Test Ignore this',
                            description: "Test Ignore this",
                            project    : [
                                    key: projectNewIssueKey
                            issuetype  : [
							//Need to define issue links here?
        .asString().bodyI've found a rest example of this but I am unsure of how to convert it to scriptrunner/groovy syntax.
https://docs.atlassian.com/jira/REST/cloud/#api/2/issueLink-linkIssues
Any help would be much appreciated.
Kind regards
Thomas P. Hargreaves
Hi Thomas,
We've put an example of how to do issue linking in our documentation: http://scriptrunner-docs.connect.adaptavist.com/jiracloud/post-functions.html#_link_to_an_issue
The link has to be created after the issue is created, they can't be done in one request.
I hope that helps,
Jon
  Hi Jon,
Fantastic, thank you very much.
