Creating jira (5.2) issue from crucible (2.9.1) fails
chrisi
When i am trying to create an issue from crucible i get the following error-message:
Error creating subtask in JIRA: Unknown error creating subtask for issue SANDBOX-1: null
in jira i have the following logoutput at the end of the stacktrace:
Caused by: java.lang.RuntimeException: Issue 'null' has no project
        at com.atlassian.jira.issue.fields.screen.issuetype.DefaultIssueTypeScreenSchemeManager.getFieldScreenScheme(DefaultIssueTypeScreenSchemeManager.java:149)
        at com.atlassian.jira.issue.fields.screen.StandardFieldScreenRendererFactory.createFieldScreenRenderer(StandardFieldScreenRendererFactory.java:49)
        at com.atlassian.jira.issue.fields.screen.FieldScreenRendererFactoryImpl.getFieldScreenRenderer(FieldScreenRendererFactoryImpl.java:49)
        at com.atlassian.jira.issue.fields.screen.FieldScreenRendererFactoryImpl.getFieldScreenRenderer(FieldScreenRendererFactoryImpl.java:43)
        at com.atlassian.jira.web.action.issue.IssueCreationHelperBeanImpl.createFieldScreenRenderer(IssueCreationHelperBeanImpl.java:191)
        at com.atlassian.jira.web.action.issue.CreateIssue.initTabsWithErrors(CreateIssue.java:362)
        at com.atlassian.jira.web.action.issue.CreateIssue.getTabsWithErrors(CreateIssue.java:353)
I am using the default sub-task issue and the default workflow. application-link subtask settings are as follows: type id = 5 / resolution action id = 5 / resolution id = 1.
what went wrong?
chrisi
somehow, restarting fisheye solved the problem.
before this error occured the first time i had a test-project which i deleted and recreated with the same name and key. maybe there where some leftovers in the memory which led to this error.
maybe this is a bug and i should open a ticket...
