I have an issue that contains a numeric field called "quantity". I'd like to be able to create a number of new issues based on the quantity field. For example, if the quantity field has 10, I'd like to create 10 new issues. If it has 100, I'd like to create 100 new issues.
The creation of issues can be triggered manually, though I would like for the 10 issues to be created automatically without having to create them one at a time.
I have been exploring JIRA automation and I could not find a suitable loop condition or a trigger.
What is the best way of implementing this?
Thank you,
Girish
I don't think there is a way to do that using Jira's native capabilities. It would be great if such functionality could exist, but for now you simply can't do anything out of the box.
My best guess would be:
Hi @Alex Koxaras -Relational- ,
Thank you for your response. I had come to the same conclusion on JIRA's native capabilities.
I will review the REST API posts you sent me. Do you have any pointers on where to start with Scriptrunner? I am a newbie with Scriptrunner so any suggestions would be helpful.
Thank you,
Girish
@Girish Ramachandran going to the vendor's website is a good start. In addition their library might have something in it.
If you've figured this out by now I would greatly appreciate any insight as to how you to achieved it.. I know this has been inactive for a couple years now..
