Cross Project Release on Advanced Roadmap
Anna_Gosline
September 6, 2023
Is it possible to create a view in Advanced Roadmaps that group the cross project releases together.
show both prog and train epics rolled up under Release 1.3
as shown below:
Danut M _StonikByte_
Hi @Anna_Gosline,
Have also a look over this article on our blog: How to track multi-team or scaled-agile projects (such as SAFe®) in Jira with Great Gadgets app.
With this app you can create a timeline (burnown with forecast) for your entire release.
Also you can create powerful dashboards for tracking your release overall and the work of each team.
I hope this helps.
Thank you,
Danut Manda
Laurie Sciutti
Hi @Anna_Gosline ~ "A Project Timeline can only show issues from one project.  Cross-project planning is only possible in Advanced Roadmaps, which is included with Jira Software Premium and Enterprise."  ref:  https://support.atlassian.com/jira-software-cloud/docs/what-is-the-roadmap/
So since you have Premium, you should be able to do this.  I don't have access to that in Cloud though, so I'm unable to have a look but this seems to provide the steps you need:  https://support.atlassian.com/jira-software-cloud/docs/create-a-cross-project-release-in-advanced-roadmaps/
HTH.
