×We have 31 cross project releases configured in JIRA Advanced Roadmaps, however for some reason not all 31 releases are displayed.
The UI seems to make provision for additional releases (the navigation bar allows scrolling down further) but no releases are displayed.
Is there a limit or setting that should be changed to allow for the display of additional releases?
Nice to hearing from you. Trust you are well.
With regards to your question ... I doubt this is any limitation. You probably checked that, but still ... maybe appropriate issues are not shown on the Roadmap so there's no point in showing that Release?
On a separate note ... 31 release is a decent number. I am wondering how you track it and orchestrate it. Plus how many projects your release span to.
Would welcome the opportunity to learn for your use case and share some the good practices we built into our Release Management App. If you are to it please opt-in here:
https://docs.google.com/forms/d/e/1FAIpQLSdvVBm5KK5wTNosLqyP9iKUI8GOoqZn8kQEyV-1yAOJZEwKxQ/viewform
Many thanks & kind regards,
Yuri.
Welcome to the community.
As far as I know, there is no configurable limit. Is it applicable in different browsers?
It could be better to create a support ticket to Atlassian if there is a display issue.
