×Is it possible to add a custom field to a project?
As far as I know it's not possible out of the box, but there are plugins you can use like :
https://marketplace.atlassian.com/plugins/com.deiser.jira.profields
Not sure if this is the only option - you have to search if there are free plugins that can do that....
I'm trying to create a plugin so if they could do it, I'm assuming I can do it also. Thank you.
Well you can add custom fields to issues. I was wondering if you can do the same for projects? For instance if I wanted to set a bugdet for a project. That doesn't exist. Can I add it?
What do you mean exactly by "add it to a project" ?
