Custom Field check option to be added in issue level.
Andrew W Matthews July 24, 2023
The client requirement is that they want to create a criteria field that will not have a definite option like in checkbox field.
They want it in a way that depending on the task to be performed in each issue the options should be able to be added.
E.g. If I create a checkbox field and add option Option 1, option 2.
When an Issue is created if neither is useful they must be able to create an option 3 for that particular issue.
I know that the jira features don't support this, but is there any add-on that can be used for this purpose.
Thank you.
Dexter de Vera
Hi @Andrew W Matthews ,
If they are not using the component field, maybe you can suggest to use the component where as a project administrator can add/remove value in list without need of Jira administrator.
Hi @Dexter de Vera ,
Even that has limit, some option will be Multi-text.
Also They are using Components and labels as well.
Neither of the 2 fits the criteria.
Like John Funk likes this
SERVER
VERSION
9.3.0
