Custom Field "Account" set as required and locked in field configuration. However on some project it is mandatory but not mandatory on others.
Please can you see if this is a bug on your end.
A example project it is not mandatory is Automotive platform PSA
This is the Atlassian Community, not Atlassian Support.
They can be reached via -> https://support.atlaissan.com/contanct/#
Are you using the same field configuration scheme, with the field configuration where the account field is set as required on all projects?
