I have successfully created a custom field, and it has been added to my Screen Scheme. And I see it when I Create, edit and view an issue.
I would like this field to only be visible on the view and edit Issue.
The intended use of this field is to be set once the issue is resolved (I have configured the Resolution Screen to have this field, and this part works fine)
Is this possible to do?
David
Hi David,
this is very possible, but you'll need to make use of Screen Schemes in order to assign different screens to different Action.
There's 3 possible actions:
For each of those types, you can apply a different screen, and on those screen you can add or remove fields as you see fit so you show a specific field at creation and not at edit or vice-versa.
Hope this will help,
Ah thank you David,
I had the same screen for Edit, View and Create. I tried to edit them individually, but as I added/removed the field from each - it changed it on all of them - which makes sense as they are all the same screen.
Glad you figured it out!
