Custom Fields Not Displaying on Plan Timeline
Vivi Osorio
April 30, 2025
I'm having an issue with the premium plan.
I created a plan using a filter, which automatically created a Timeline view.
The timeline, under the "List" view, grabbed default columns. I added additional columns, but these are only visible to myself. I would like the rest of the team to see the columns. The columns are not empty.
Thank you so much!
Sanam Malleswari
Hi @Vivi Osorio
There’s currently no global column configuration setting that applies to all users in Advanced Roadmaps. However, here are a couple of tips:
Ask your team members to manually add the same columns by:
  • Going to the Plan.
  • Clicking the "Fields" dropdown (top-right of the List view).
  • Selecting the custom fields you added.
ENTERPRISE
