Custom Fields not showing in JEMH Post Function To: CC and BCC
TasneemB April 15, 2016
Hi
I created a custom field whose value I would like to be in the To field. After creating it and going to the post function, I am unable to see the custom field in the selection list of To, cc and bcc. It is however in the Reply-To  selection list. The field is single line text field. Only some of the custom fields show in the to, cc and bcc lists.
I also checked the tick box at the bottom regarding the custom fields. I still don't see the fields in the list.
Please advise.
TasneemB April 18, 2016
Hi there
It is version 1.7.47. Is there anyway to get around this issue and get the new custom fields in the selection, without changing to another version?
Thanking you
Mike Harrison
April 19, 2016
I believe that a JIRA restart will rebuild the cache that is used also.
Mike Harrison
April 18, 2016
Please can I ask what version of JEMH you are using? A bug relating to new custom fields not showing on this screen was fixed in 1.7.63/1.8.23.
Mike
