×I am very confused by the information on the website and I am still unsure of the workflow for this. What I am trying to do is:
- Create a custom issue type in a Project
- Specify the fields that show up when that issue type is selected within the Project
A project have only one Issue Type Screen Scheme, but can have many Screen Schemes under that Issue Type Screen Scheme.
In a Issue Type Screen Scheme, we will specify Screen Schemes for particular issuetype.
like ScreenSchemeA for Bug
ScreenSchemeB for Task and soon.
In a Screen Scheme, we will specify Screens for particular operation.
like Screen1 for Create
Screen2 for Edit
Screen3 for View
In a Screen, we will give fields(include system fields and custom fields)
check https://confluence.atlassian.com/display/JIRA/Associating+Screen+and+Issue+Operation+Mappings+with+an+Issue+Type#AssociatingScreenandIssueOperationMappingswithanIssueType-Associatinganissuetypewithascreenscheme for selecting screen scheme for each issue type.
Hi Henrik
You can basically create Issue type screen scheme, allow you to associate to different issue type which will then map to a particular project, for more information on the relationship between field and screen, you may refer to the following documentation:
Having the same problem.
I'd like to associate more than one screen scheme with a project.
Going to Projects > Screens > Actions. It looks like only 1 scheme can be selected. See also https://confluence.atlassian.com/display/AOD/Associating+Screen+and+Issue+Operation+Mappings+with+an+Issue+Type
How can I have 1 project with different issue types that each show a different set of fields when that particular issue type is created?
have you gone through @Bharadwaj Jannuanswer?
project will have only one Issue Type screen scheme and each issue Type screen scheme will be associated with multiple screen schemes(issuetype level)
Hi Christina,
first you would need to associate your issuetype with the issuetype scheme used in your project.
Second, create your fields, add them to a screen, add this screen to screen scheme (for varoius issue operations). Then map this screen scheme to the issuetype in an issue type screen scheme and associate that with your project. That is basically it.
Udo
Can you associate more than one screen scheme with a project?
Yes, one screen scheme for each issue type
