I want to add a custom default project avatar? How can I do that?
Domenika
I dont think this is possible through any of the configuration screens. You could possibly just change the images that are used which is under {JIRA_DIR}/atlassian-jira/WEB-INF/classes/avatars. These should be rocket.png, medium_rocket.png and small_rocket.png. As long as they have the same name, your default image should change but it is a bit of a hack rather than a configuration change.
Hi Domenika,
look here: http://confluence.atlassian.com/display/JIRA/Defining+a+Project
Best regards
Thomas
