Custom field is emptied on Create Issue
Joe Mallon
April 11, 2014
Jira v. 5.2.11
I have a custom field that is a version picker. On Create Issue, it accepts values, but when the issue is submitted, the field is then empty. The field can be filled successfully on Edit.
I've checked via Javascript that there are values in the field while the Create form is being filled out, but once the submit happens, the values are gone.
How should I start exploring this issue?
Fabio Racobaldo _Catworkx_
Hi Joe,
please could you check if on your create transition there's a post function that purge this custom field?
Let me know,
Fabio
Joe Mallon
April 13, 2014
That was precisely the problem. We added a post-function to clean out fields durign cloning.
