Custom field not showing in Jira issue widget anymore
Toon Verschoor
March 11, 2025
Just two weeks ago, I still was able to use the Jira issues widget to show a set of Jira issues within a Jira ticket. I used to show an overview of all issues within a release. One of the things that was important was to show that a custom field called Release notes was filled for all issues.
I'm now unable to show it anymore. I can select it, but it is not showing anymore.
Any advice?
Mykenna Cepek
April 7, 2025
Hi @Toon Verschoor, welcome to the Atlassian Community Forums.
I'm fuzzy on the problem you're encountering, which makes it hard to suggest things to help or try. Adding screenshots here of what's not working, particularly error messages, can help.
Things like "widgets" (gadgets) can be used on Jira Dashboards and on Confluence pages. Knowing those details will also allow folks to be more helpful.
If you've figured it out since you asked this question, posting what worked for you here can help others learn from your experience.
FREE
