Does anyone have an example groovy script for a custom field using ScriptRunner that would display an image/icon with the radio button?
Hi James,
I was checking on https://library.adaptavist.com/ if there is any script covering something similar to what you are requesting, but unfortunately I couldn't find anything.
But I might have missed something, so worth double checking there though. Library has tons of scripts.
If you can't find anything helpful in Library, I would recommend you to reach out to Adaptavist Consultants: https://www.adaptavist.com/atlassian-consulting-services/
They will be able to write you a custom script that covers your need.
Is there a way to accomplish this without using ScriptRunner?
For instance, can I put an image in a directory on the server and have a radio/checklist load the image? This can be done with confluence macros but I'm not sure how to do this in Jira.
