Custom fields layout on project quick view
Yonatan Leket September 26, 2019
Does anyone know if there's an option to edit this layout?
I want this quick view to include fields other than the issue's summary.DBB.png
Krister Broman _Advania_
September 26, 2019
Hi Yonatan,
Unfortunately i am not aware of any ready solution (out of the box or through plugin) to allow you to do that. I guess its possible to hack it yourself if you are knowledgeable enough.
I would suggest instead that you utilize the Backlog/Sprint functions, these will allow you to add up to three user specified fields to the cards configured through the board configuration.
