Dear,
We would like to have the following:
During the creation of a new project the creator can add a list of timesheetcodes that can be used for that project. Every time you create an issue you can define one of these codes using a dropdown box in the create issue screen.
What I've found so far is that I can create a customfield voor this Timesheetcode on the create issue screen, however I have no idea if it's possible to add a list of valid timesheetcodes for that particular project and if we then can link the dropdown box to this list.
Best regards!
Hi @Yannick Wellens,
you can do this with a custom field and its context like this:
Hey Thomas,
My apologies, just found that out myself after looking into it a bit :D. But thank you for your response!
Best regards
You're welcome, @Yannick Wellens - maybe other users with the same question will be happy, if they find the answer here.
