I've created custom workflows, screens, fields that I want on my projects. Mostly from the default screens. While editing those screens I can hit the Create button and my screens look great. However when I navigate back to my Project, Kanban or Issues, screens I hit the create button and I get a kind of default screen.
How do I associate my new screens with the screens I've just created?
Hi Joshua,
Here is the basic logic. Screens got mapped to actions (Screen Scheme) and issue types (Issue Type Screen Scheme).
Actions are: View, Edit, Create and any workflow transition.
Issue Types are the issue types you have configured for the project.
As a result you can have one screen to create a bug, but another to edit it or the create bug screen for bug and user story can be different.
I hope this helps if you need more detailed information let me know.
Cheer,
Peter T
Hi Joshua,
did my answer resolved your issue?
