I have many projects assigned to a single screen
this is a configured Screen and all the projects are using the same fields because they are reading from only a single Screen
we have a Module field that contains different values for each Project, this module exists as drop down field on the screen
how can I a put a customized module drop down that is independant for each project
for example if i create a project A it has for drop downn Module: Mdl1,Mdl2,Mdl3,Mdl4
if i create a project B it has a drop down Moule :Mdl 8,Mdl9
and so on and all the fields are the same
Please help
You can make more than one custom field using the same name. so, you make a custom field for each project with values you like in that project, add them all to same screen, and you are done. Since for each project there is a custom field, and each is limited to a specific project, each projects screen will look the same.
great Josef how do I make?
please give me a walkthrough thanks
I think I got your point,
First If I have 10 projects
I should add 10 custom fields and add these fields to the Screen
Please correct me if I am wrong
yes, exactly. your screen will have the 10 custom fields, you'll see one in each project.
